Showing results for tags 'lg motor overheat smell'.
Hi I have an LG WD-80481TP that have served me well for the past 9 years without any problems. Yesterday during a regular wash cycle we noticed a burning smell so we stopped the wash cycle and later i tried making a quick spin cycle to dry out the clothes but the cycle failed, the machine simply shutoff after 20 minutes of attempting a 10 minutes spin cycle. after investigating it the motor is overheating, its spinning the drum but only at low speed it seems not to reach high spin speeds and it appears to find it hard to start the spin, when the machine shutoff it kinda went crazy the time was going down one minute every 5 real minutes and then eventually it kinda turned off and on in a split second extending the cycle time to 17 minute and then on and off again to shutdown with a burning smell coming from the motor. I have checked the following: - Drain pump is OK, it successfully pumped the water out of the machine. - Belt seems OK as the motor is successfully turning the drum, the belt seems in good shape and moves the motor rather easily when manually spinning the drum, its also cold to the touch. - Motor is noisy and burning HOT in minutes after operation, i could also see electrical sparks coming out of it, its kinda trying hard to start then it spins a little bit and stops. - I suspected Motor Brushes were worn out, However after taken them out they have a good 3cm+ left on them. - I checked the motor sensor with a multimeter and i got around 5 Ohms, 7 Ohms for the brushes and 1-2 Ohms for the the 3 motor wires, as i understood these values should indicate a functional Motor. - The drum bearing should be OK since the drum moves freely without noise. From your experience could you tell if this means the Motor is faulty or perhaps some logic board controlling the motor is at fault? Thanks alot for your advice Note: I have already checked troubleshooting section https://www.whitegoodshelp.co.uk/washing-machine-not-spinning/ however the burning smell in addition to the sparking are leaning me to think its a faulty motor rather than something else, wanted an experienced view if its most likely the motor then apparently the machine is not worth fixing.
