Showing results for tags 'indesit w113'.
  1. I wonder if anyone can offer some advice regarding the following issue. My Indesit W113 has started to get stuck very early in a cycle. Other drain, wash and spin cycles are ok if I reset and go directly to them. I suspect the heater or thermostat is at fault. I disconnected & checked the heater and got approx 31 ohms reading with a meter. I am now at a loss to find the thermostat. I'm used to seeing it embeded into the drum via a rubber grommit and with wires coming from it but I can't find any wires or any rubber grommets containing a thermostat. Is there a thermostat that monitors water in drum temp on these machines and if so where is it located? Percy
