Showing results for tags 'hot water to hot'.
  1. Greetings We have a Miele 765 washing machine are we have two problems 1. I seems when we set the temperature to half way to 85 or on 85 the water is too hot. Steam is created in the laundry room and the machine glass door is very hot to the touch. 2. There is a water leak somewhere either the detergent dispenser and or possible the water pump itself. It seems to leak more when we use the hot water cycles. I cleaned the detergent dispenser regularly. Please note the machine is on a wood stand which is mounted to the floor and the machine is mounted on the wood stand, which is very hard to work on. Any help would b great... Big thanks damon
