Showing results for tags 'half load'.
  1. When you half or quarter load a washing machine drum and it starts washing and 'violently' sloshes the washing around (ie lifter/paddles lifts washing to top of drum and then the washing slams to bottom of drum) could this not damage (this sloshing/slamming action) the garments over time and indeed the paddles of the machine , (or both) - I relise that the proper way to load the drum is not fill it right to the brim of the top of the drum, you have to leave a vertical hand width height of free space dont you? - but if you do that the clothes will slosh and rub against each other (friction - simulation of rubbing the clothes together) to get them clean , but when you half fill or quarter fill a drum they can slosh with quite a thud, especially in a 9kg size drum. ?
