Showing results for tags 'fills and empties at the same'.
  1. Help, I have a hoover washer. When filling, the water empties out of the drain pipe so it doesn't stay filled with water. When the washer is trying to fill, water is going out the drain pipe at the same time. Also the dial when set to 4 stays at 4. The washer does spin when set to six (6=spin cycle), Could this be a control unit problem? Any suggestions?
