Showing results for tags 'fault f16'.
  1. I have a Bosch Classixx 6 1200 spin washing machine. It keeps showing a Fault F16. I looked up this fault and it says keep door closed or linen stuck. I replaced the door lock mechanism with a new one after checking wiring and original door lock and trying all other possibilities. After putting the machine back together it is still showing the same fault code. Any ideas about what to do next? Thanks C
