Showing results for tags 'error 3e'.
  1. Hi... We have a new issue with the above washing machine. Usual faults are the filter blocked with pocket rubble etc but tonight's is different. The washer powers up and is able to select a program. When starting the program it just sits there with the upper left icon flashing..looks like a water fill symbol. It just sits there and doesn't advance. I've checked the water inlet filter but it was clean. We live in a very soft water region and dont have any problem with hard water issues. EDIT:Just been running it again and left alone for a bit... Error code 3E has appeared on the display. Can anyone suggest a cause of this please? Thanks Chris.
