Showing results for tags 'dryer fan'.
  1. Hello, This is my first post. I have a Hoover washer dryer (H-Wash 300 H3D 496TE NFC 9 kg Washer Dryer) which doesn't dry the cloths. I have checked the Heaters, TOCs and those were good. But the fan is not working. However if I give power to the fan separately it works. (Disconnect the fan terminals from W Machine and gave direct 230v AC supply to the motor.) So what can be the issue? How to fix it? Other than this issue everything else works fine. Thank you very much for everyone who maintain this kind of forum.
