hi, I've got a hotpoint ultima 1400,when you close the door it says select program,which is normal,so you select program, press start and after a while it flashes up "close door" even though the door is full closed. I thought it might be the door interlock switch,so changed it but not worked,still does the same.any ideas .cheers
ady
