Showing results for tags 'bosch drain 1 second'.
  1. Hi, I have a problem with my washer where it's stuck on one minute and never finishes a cycle or drains. I know this has been discussed a gazillion times and often it's down to a blockage. I had all the pipes connected to the pump off last night, and cleaned them all out so they're like new. The filter is clear and I can see the impeller spinning. It makes no difference if it's a cold or hot wash (the heater element is definitely working) and even running a spin or drain cycle doesn't help. I've made a short video of the noise it makes when it should be draining here. Any ideas please? It sounds like the bearings on the pump maybe?
