Showing results for tags 'Hotpoint WDD960 Dryer'.
  1. I have a hotpoint WDD960 washer dryer. The dryer no longer dries. It goes through the motions but the washing comes out cold and wet. I removed the lid and checked what appear to be two thermostats on top of what appears to be the dryer unit. One of them is open circuit the other is short circuit. I think thermostats should be short circuit if not faulty. I have added a picture of the dryer viewed from above with the washer lid removed. The open circuit device is on the far right attached by a brown ( looks pink in the photo) wire. The short circuit device in the middle attached to a blue wire. Both devices appear to be held in position by bolts and have just the one centre terminal using the frame of the dryer as the ground. Can anyone confirm if what I have said is correct, if this is a thermostat and if so where I can get a replacement? I assume the other (blue) wires go to the element? Maybe I have this completely wrong. I didnt go as far as disassembling the unit yet! Can anyone help?
