Showing results for tags 'Heater Open Curcuit'.
  1. Hi Everyone I have a problem with my Bosch Exxcel W/M First fault was blowing of 13 amp plug fuse Investigation narrowed it down to Heater and on removal element was totally knackered/ corroded - short circuit Ordered new heater element genuine Bosch part I was told as no copy patent part available Fitted new heater and wash cycle would not finish - no error code. Research suggested open circuit heater and after metering realised this was the case Ordered new heater element (stupidly didn't check for continuity) fitted and still same fault new element is open Circuit ! Question.. Have I been sent two faulty Elements or is the Machine taking out the new elements? Totally confused !!! Help please!!!
