Showing results for tags 'Bosch Logixx not heating'.
  1. Hello, In the last week this washing machine has stopped heating the water - I can tell this because I have an energy monitor that is only showing a slight increase in consumption during all parts of the cycle (0.5-1.0kwh compared to up to 3kwh before) during usage, plus the door glass is stone cold throughout the cycle, even on a 90degree cycle (before last week, even on a 30degree it would warm a small amount) I am unsure how any fault codes would be displayed, the machine has an LCD text display (when I once turned the machine off with the water supply off a message appeared to this effect so I would expect some kind of feedback to any problems on here) but there is nothing different showing to the normal progress of a cycle and no [different] flashing of the other LEDs. There is also no real difference in the time the cycles take to complete (compared to a week ago when it did seem to be heating up as normal). The model number is WFR3267GB/04 and it is branded Bosch Logixx 1600 Express. I can not think of anything unusual that has happened in the last week. Any ideas please? Thank you.for your time.
