Showing results for tags 'Beko Tripping Power'.
  1. Hi there, Any help would be great. I own a Beko WM5120s washing machine. It has started tripping out the power at the beginning of a new wash. I put it on and the pump runs for about 2 seconds then the power trips. I am wondering if it is the pump that needs replacing? The first time this happened was at the end of the cycle when the water drains and it tripped then making think it was the pump. I have taken a look inside and there is no water leaking on any parts and I cannot see any loose cable that could be causing a short. Any help would be great Cheers Tom
