Curious Posted May 18, 2006 Posted May 18, 2006 The door hinge on my mother's 18 month old Hoover washer has broken. I can easily remove the door, but I can't work out how to remove the hinge from the door to replace it. I've tried undoing the four screws on the reverse of the door, but I still can't get the door apart to remove the old hinge. Is there a special way to replace the hinge? It's a die cast hinge.
Root Admin Whitegoodshelp Posted May 18, 2006 Root Admin Posted May 18, 2006 The door is in two halves. Separate them by inserting a small screwdriver between them and gently prizing apart. Once inserted, slide the screw driver round to separate all the way round. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
