Have you ever found your washing machine leaking after you have recently cleaned out the pump filter? - Cleaned pump filter now it leaks
Do you think the time remaining display on your washer is not accurate? Time remaining display not accurate
Beware of using small colour catchers - Colour Catchers Can Block Washing Machine Pumps
How to get drum shaft out of drum bearings if they have collapsed and seized up - Can’t Get Drum or Bearings Out
