louden255 Posted October 1, 2019 Posted October 1, 2019 I have recently had an integrated machine installed (a Zanussi Z716WT83BI Washer Dryer). The installer has continued the kitchen skirting around the front of the machine. According to the diagrams in the user manual, this obscures the pump and it's filter from being accessed. Am I being stupid, or is this the case? Has the installer made a mistake which means I can't access the pump and filter to clean it?
Root Admin Whitegoodshelp Posted October 1, 2019 Root Admin Posted October 1, 2019 Hi. Yes you need access to the pump filter. You also need to be able to pull the washing machine out. However, the kickstrip should only be clipped in place and should be able to be pulled away from the kitchen units. It may come away in one large piece. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
louden255 Posted October 2, 2019 Author Posted October 2, 2019 Hi Andy, Thanks for your help! I'll have a look and see if it can be removed as one big piece. If not, I think I'll have to get in touch with the installer.
Root Admin Whitegoodshelp Posted October 2, 2019 Root Admin Posted October 2, 2019 No problem. The kick strip plinth in a kitchen usually has several clips at the back. These clips push onto the feet of the units. The kick strip plinth has to be installed so that it can be easily removed otherwise it is not installed properly. Quite apart from being able to access the pump filter the washing machine clearly will need to come out to be serviced and repaired, or even replaced. Just start gently trying to pull it away. Obviously have a look for some screws first in case it is screwed in place instead, or as well. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
louden255 Posted October 4, 2019 Author Posted October 4, 2019 Hi Andy, thanks again - you were absolutely right! It had just been installed so nearly that there was no gaps or anything, but have found a little handhold for removing it and accessing the pump/filter. Whitegoodshelp 1
