Graham Posted September 4, 2006 Posted September 4, 2006 I need to move my washing machine into my garage where the floor is about 3 feet below and 12 feet away from the floor that contains the sink that I need to empty the machine into. Does any one have any idea whether a standard washing machine pump would cope with that or, if they won't, the best way to incorporate a secondary pump. ie in line or via a secondary tank that the machine could empty into?
Root Admin Whitegoodshelp Posted September 4, 2006 Root Admin Posted September 4, 2006 A washing machine pump is designed to pump water about 2 - 3 feet. If the drain hose is fixed an extra 3 feet above the top of the washing machine it would increase the height to 6 feet and although the water would possibly pump out the flow will be substantially reduced. It's unlikely a washing machine could pump water fast enough to either rinse properly, or to not time out (and abort) on empty.If your washing machine would only have to pump 3 feet in total, and then run 12 feet it could work although it couldn't pump the water 3 feet plus a further 12 feet so the last section would have to have a decent slope towards the drain.You can buy a proper pump system that can pump water quite a long way, designed for washing machines in a basement needing to pump upstairs Saniflow make such pumps. Some of their pumps can allow a washing machine to pump up to 5 metres high.Finally, raising the washing machine itself by installing it on a secure platform and hemmed in so it can't fall off can reduce the height needed to work properly. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Guest Guest_Graham_* Posted September 6, 2006 Posted September 6, 2006 Thanks for your advice, I think that makes up my mind, I'll install an intermediate tank and a separate, secondary, pump.
Root Admin Whitegoodshelp Posted November 4, 2013 Root Admin Posted November 4, 2013 I have an article now on this subject here - installing a washing machine in a basement Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
