Does anyone know how to set the dryer to high or low?
I can select cupboard dry, iron dry or timed, but don't want to shrink clothes by mistakenly using the hottest setting
Thanks in anticipation
Most modern dryers don't have high or low heat settings any more. The temperature is decided by the programme selected. Programmes are similar to on washing machines, with cottons, delicates woollens etc all with appropriate heat settings. You might be able to download an instruction book
  • Whitegoodshelp changed the title to Washer dryer high and low heat settings?
