Showing results for tags 'drain hose'.
  1. Hello. I built my kitchen cabinet with 860mm height. And my washing machine has a height of 844mm. The water outlet will pump water out of the washing machine. The plan is to plumb it under the sink, so that it will pump water directly into the pipe under the sink. However, pipe hole is quite high at 650mm above ground. Hence, the water might converge inside the pipe, or even move into the washing machine hence malfunctioning it. Any solution to this?
