tumbler Posted April 1, 2020 Report Share Posted April 1, 2020 Following certain error messages I've bought a couple of spare parts for our AEG 74600: the water distributor and the solenoid water valve. However I am having a hard time figuring out how to join the two parts together (there's not enough room). When de-attaching the old parts I opened up the water distributor (hoping I could fix it), and this also made it easy to de-attach and rejoin it to the water valve, but I can't imagine I'm supposed to disassemble it prior to mounting and joining the two parts. I've also tried to see if I can remove the rear "wall" in order to get enough room but there's no obvious way to do this. Any ideas? A service manual would be nice, but nothing pops up online. Water distributor (source: AEG shop) Water valve (source: AEG shop) Link to comment Share on other sites More sharing options...
tumbler Posted April 2, 2020 Author Report Share Posted April 2, 2020 After posting I opened my eyes and realized the obvious: there's a metal frame at the top front of the washing machine (behind the control panel) which can be removed with 4 screws! This allowed me to attach the water valve first, then have enough room to (firmly but carefully) push the water distributor forward and attach it to the water valve. Pictures say more than words, so see below. As you can see, I also disconnected the cable from the front control panel (buttons, display etc.) which wasn't easy and could possibly risk damaging the cable/plug. In hindsight I could probably just leave the front panel dangling and still be able to attach the water valve/water distributor. You can see how it's now possible to attach the new parts, with the extra room in the front. Note that the front end of the water distributor is to be aligned with the holes in the metal frame (after the metal frame and front panel has been re-attached), with screws on the right hand side (view from front). When attaching the existing cable connectors to the water distributor I found they didn't fit! The two connectors were all wrong -the old water distributor didn't have any such connectors, but the mating connectors went directly on a couple of electronic circuit board (PCB) "slots". It turned out the white plastic "frames" on the new water distributor were easily removable by pulling them outwards with pliers! Then the old connectors would fit. See photo below: I suppose the water distributor might be used with other washing machine models using different connectors or later sales of this washing machine had revised cable designs or something. The good news is that now, with a new water distributor, water valve, door-switch and a good cleaning (I took the time to manually clean the inside of the water inlet dispenser-hose (filled with grime), the inside of the rubber door-seal (also filled with dirt) as well as the water outlet (front left bottom of the machine) to get rid of any sand and dirt. Finally I've given it a full 95 degree cycle with one of those cleaning packs from the local supermarket. I won't be surprised if our clothes get a lot cleaner after all this! By the way, can someone suggest what I do about all the rust spots below where the detergent drawer goes (1st photo in this posting)? I believe there are enamel repair kits, but based on prior experience they haven't really worked that well. Whitegoodshelp (Andy) 1 Link to comment Share on other sites More sharing options...
Root Admin Whitegoodshelp (Andy) Posted April 2, 2020 Root Admin Report Share Posted April 2, 2020 Many thanks for sharing that. Need a repair or spare parts? Book a Repair | Buy appliance spares (Cheapest prices guaranteed) Warning: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith. Link to comment Share on other sites More sharing options...
tumbler Posted April 2, 2020 Author Report Share Posted April 2, 2020 You're welcome Link to comment Share on other sites More sharing options...
