Appliance Offers
Lincon
Whirlpool AWO/D 049 problem
Hello everyone,,
Seem to have a problem with my integrated washing machine.
I've put it into test mode and this is what happens...
The lights all flash showbox.bio/ tutuapp.uno/ vidmate.vet/ across for a few seconds. Then it sounds as though the pump runs for 2-3 seconds, then everything stops. The red service light lights up solid, not flashing. The Wash and Rinse lights light up green solid, not flashing. And the Start button flashes green.
I've tried a few power resets and drains but not sure what to try next. It does the same as the above when I try to start any of the usual cycles as well.
Any help would be very much appreciated.
Thanks in advance
Share this post
Link to post
Share on other sites
Book washing machine & appliance repairs Buy appliance spare parts
I don’t know what it’s supposed to do exactly in test mode but I would expect a washing machine to run the pump at first and then take some water in. Also some test modes might require a button press to move it on. Also, what was the fault that prompted you to try the test mode?
Need an engineer, or to buy appliance spare parts? Please use my affiliate links to support this forum.
Book appliance engineer | Buy your Spares (4Washerhelp)
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Restore formatting
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
