Ransom Spares
Sign in to follow this
Chrispick77
Miele leaking internally
.Hi I have a miele g1270svci dishwasher that has just started coming up with the f11 fault. I first checked the drain pump and impeller for obstructions and it was clear but I no noticed some wetness on the bottom tray after removing the front middle bottom panel.
Upon removing the bottom tray I have noticed i have had a leak for some time and had some rusty screws and clips.
I have found the leaky part butbinjow need some help identifying it.
I took the left side panel off and there is a plastic tank and at the bottom left of the tank is a white thing connected. This is where my leak is coming from.
I dont know if it's the tank or the white thing that is leaking but what exactly are they both?
I will upload pictures when I find out how to
Share this post
Link to post
Share on other sites
Ransom Spares
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Restore formatting
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Get Which? for £1
Ransom Spares
