Gary
BEKO WMB 61022M not starting
Hi I have a Beko WMB 61022 M that will not start. I have had it for about 4 years and it has been fine. The lights come on and I have changed the door lock switch but no change. I have checked voltage at the switch and that seems ok, 220 across middle and right or middle and left. The control panel shows no indication of burn out. Any suggestions would be very welcome. Thanks Gary
Share this post
Link to post
Share on other sites
Book washing machine & appliance repairs Buy appliance spare parts
Hello Gary. I have a full article on this subject here Washing Machine Won’t Start. This is not good to be checking voltage inside the washing machine though. Testing for power getting through should be done with a continuity test meter which is totally safe. On some washing machines and open circuit motor of faulty carbon brushes in the motor can cause the whole washing machine to go dead. But usually this is a fault that can have many different causes I'm afraid.
Need an engineer, or to buy appliance spare parts? Please use my affiliate links to support this forum.
Book appliance engineer | Buy your Spares (4Washerhelp)
Share this post
Link to post
Create an account
Register a new account
Sign in
