Miele W3164 Edition 111
Pebble
Yes it does Pebble. There's also a drain only option.
Link to comment
Share on other sites
Cheers. Send me a link to your music too. The drain/Spin cycle is just after 6 O'Clock on the dial. If it's producing an error F11 the most common cause is a blocked pump filter. However, if it fills up OK with water then if the pump filter (or anywhere else) is blocked then it won't drain out the water. Is it pumping the water away OK?
Link to comment
  • Members
It fills up fine no problem. I have followed the instructions to cleaning of the drain filter and drain pump.
Found nothing there that's blocking it so, there must be a blockage somewhere else.
The prop spins just as you describe in your other diagnostic tests.
Is it not possible to spin without the rinse?
Link to comment
  • Members
> Is it not possible to spin without the rinse? <
I've sorted that Andy. When one takes of the cover of the drain filter and removes the filter and look inside, I can see the propellor and before that on my right hand side ther is a outlet. Is that where the water drains out?
Here's my links.
Link to comment
That's weird those soundcloud links just go to my own music (Snowdune) but no matter as I've seen your page now after you liked some of my tunes (thanks)
According to the manual for that model there is a rinse and spin cycle and a spin only cycle. I'm still not sure if your washing machine is draining the water out ok or just reporting that it isn't with the error code. If it's the latter there's possibly a more tricky fault or according to the W3164 Edition 111 manual there could be a "water safety system" activation which could mean it's detected a leak in the base.
These links might be helpful but only if the washing machine isn't draining out the water properly. If it is but just giving the error and you can see the water has pumped out OK then clearly there's nothing blocked unless it's the pressure system which would need the machine stripping down to get to-
Link to comment
Create an account
Register a new account
Sign in
Appliance Repairs
Book Repair Now
Buy Your Spare Parts
Buy your appliance spare part
      Chrish72
      Chrish72
      2
    2. 2
      andyr12345
      andyr12345
      1
    3. 3
      Whitegoodshelp (Andy)
      1
    4. 4
      Arbey48
      Arbey48
      1
      3.1k
      13.1k
