New Washing Machine Help Please
Rate this topic
psychonaut
  • Members
hi, you must get loads of these. sorry.
clothes washing machine packed up blah blah need a new one probably.
so, i like meile, on a side note i bought a second hand meile dishwasher 10 years ago for £60, it was 8 years old then and it has never gone wrong. i like meile. i dont like their new washing machine prices. i get to feel that i could buy 4 cheaper ones in the time it takes for the meile to go wrong, there will have been some advances on the state of the art. maybe. maybe there isnt much more to be added to the state of the art of washing machines.
what i need from a washing machine is:
say 8kg load.
a fast wash of about 20 mins at 30 or 40 degrees
a mixed wash of about 60 mins at 60 degrees.
it needs to be quiet and not try and walk its way over the bloody floor like our current one does.
i dont care how much water or electricity it uses. an extra £30 a year in juice i dont care about as we have solar and we dont have a water meter.
thats it, i never use any other programs. all our clothes go in and they come out either 60 or 20 mins later.
i certainly dont need it connected to my smart phone or emailing me when its run out of conditioner.
weve had hoover washing machines for the last 5 years, mainly because we didnt have enough money to buy one that wasnt crap 5 years ago, then the first one died under warranty after 2 years and was replaced with the second one, which wasnt quite as crap, but was still crap and has been better but its just died and im not sure i want to repair it.
and my washing pile is getting bigger as i write this.
i have the money to buy a new meile, but i am a tight git and would rather not spend it if i dont have too!
advice and abuse gratefully received!
Link to comment
Share on other sites
Hello there. I've had my Miele washing machine almost 10 years now and it still sounds and performs like new, never gone wrong once. The thing to remember is that Miele aren't expensive, it's the others that are too cheap and that's why they don't compare. Have a read at my opinion on them here - which is totally unsolicited by them Miele washing machines
I need to write an article about fast wash cycles. They are so totally misunderstood by most users. All fast washes are designed to basically wet and rinse laundry that's not remotely dirty and has not been worn against the skin. It's impossible to wash normal laundry properly in 20 minutes or half an hour. If it was possible then all washing machines would wash in under an hour - it's what customers want - but it's not possible with current washing machines washed in detergent and trying to use as little electricity and water as possible - why do wash cycles take so long?
A lot of people use the fast wash cycles for most things and ruin their washing machines because it allows a build up of slime, grease and gunge to rot the machine from the inside - causes of smells and sludge and slime inside washing machine
Unfortunately I don't have time to study the latest washing machines but you could find a lot of useful information out as a Which? member - £1 special offer at Which?
Link to comment
  • Members
hi, thanks for that. you are probably right - miele kit is superb. (well, apart from the vacuum cleaner i have but thats another story....)
understand you dont have enough time to look at latest models....i am already a which member so have been looking....samsung have something like 12 of the top 15 best buys - what're your thoughts on them?
Link to comment
To be honest I find all the brown goods manufacturers tend to make washing machines with a brown goods mentality focussing more on fancy features and unnecessary innovations, plus they rely on third party networks of independent companies or engineers for aftersales which can result in patchy quality of service. I personally would favour AEG even though they have their faults too but at least spares, technical support and repairs are much easier to obtain.
Link to comment
If Which? give them good reviews it's likely you will be happy with it :)
Link to comment
  • Members
Andy, I completely agree what what you said regarding quick washes. Another point is that if people actually read the manual, quick washes are only designed to wash loads or less and not full loads. Washing full loads on a cycle that is only designed to take half causes excessive wear on the machine - the programming of that particular cycle means the machine is tumbling and spinning at a speed that is suitable for that capacity, but putting a full load in means that the machine will be ramping up to full spin in half the time but with a full load, causing the motor to work harder than it normally would.
The great thing about Miele is that on the cottons cycle and minimium iron cycles, the machine actually weighs the load at the start of the cycle and adjusts the water level and time needed based on the size of the load, so it will only ever wash for as long as it needs to. The machine may say it will take 2 hours at the start of the cycle, but actually, that time is the longest possibe time it will take and the machine will adjust the load accordingly. They also have the automatic 40 cycle which usually lasts about an hour and is perfect for day to day clothes.
  • Like 1
Link to comment
  • Members
Re: Samsung machines. I'm personally not a fan. Their "ecobubble" technology is actually a very old idea - using high suds to wash away dirt. That's what twin tubs used to do. However, modern detergents are purposely low-sudsing for automatic machines, so designed to be dissolved in water, not foamed up. Excessive foam in a washing machine just makes rinsing more difficult, so if you have anyone in your household with sensitive skin or any kind of skin condition, they're probably not the best choice of washer to go for.
  • Like 1
Link to comment
Thanks JetSystem, that's what I mean about the brown goods manufacturers (Samsung, Panasonic, LG), they are all brilliant at what they do in brown goods and phones etc, where constant innovation and expanding of features is king. The products are virtually reliable by default because there's virtually no moving parts in them. I'll never know what they all decided to move into white goods, which are a completely different thing. Totally different. White goods are inherently unreliable because of all the moving parts and the physical work they have to do. But instead of focussing on reliability and repairability (great aftersales network and great spares and technical support network) they appear to try and survive in the market (which many other white goods manufacturers have been in for seriously many decades) by coming up with fancy features such as bubble, direct drive and playing nice tunes etc - none of which seem necessary to me. In other words, coming into the market (in the UK at least) so late they appear to try to tempt people over with fancy features that the others don't have rather than making a better, more reliable machine. Having said that, I think they are probably just as well made as the ones they are competing with.
Link to comment
Create an account
Register a new account
Sign in
Appliance Repairs
Book Repair Now
Buy Your Spare Parts
Buy your appliance spare part
      Spamcan
      Spamcan
      1
    2. 2
      Sleekmeek
      Sleekmeek
      1
    3. 3
      Whitegoodshelp (Andy)
      1
      3.1k
      13.1k
