Showing results for tags 'Program 10 fault wmef742w'.
    • Mini washing machines. Small washing machines. Portable washing machines
  1. Our brand new Hotpoint WMEF742 washing machine had a fault on program 10 (FastWash 60min). The engineer admitted that this was a known fault that required the controller to be reprogrammed. This was a simple enough job as it only required the engineer to plug his laptop into the comms port at the back of the machine. Evidently some machines have this faulty program and some don't. The fault in question prevents the wash completing with a spin and so leaves the clothes soaking wet. The fault occurs at the very start of the first rinse phase. With around 26 minutes left on the clock, the clock suddenly drops 11 minutes down to 15 minutes. Due to this error the clock reaches 1 minute before the wash completes. Although the program tries to correct for this by jumping up to 7 minutes it only runs down one further minute and then jumps to the end and unlocks the machine before it spins. The amended program doesn't actually fix the 11 minutes that are knocked off at the start of the first rinse phase and so the program still runs down to 1 minute before it should. However, when it jumps back up to 7 minutes it does use this full 7 minutes to finish the wash with a spin. So program 10 does now work, albeit in a bodged sort of way that renders the timer meaningless.
