Showing results for tags 'Not running correctly'.
  1. Hello All I have an indesit W12X washer dryer that has developed a problem. When you start the washer running on program 7 temperature 40 degrees it will not progress onto the rinse cycle. I thought this maybe down to no heat so have checked the element.. This seems to be ok. I have dropped the meter on the two terminals above the element which I thought would be the thermostat and there is no circuit. A m I correct in thinking there should be a circuit here and that it is indeed the thermostat Thanks for any advice
