John Lewis appliances
Hotpoint Wd420 Start/cancel
  • Please log in to reply
10 replies to this topic
#1 d14ner
d14ner
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 14 July 2012 - 04:39 PM
I have checked with the trouble shooting guide and not found a solution to my problem.
My washing machine starts when I press the start button. When I try to cancel a programme, the lights all flicker to a preiod of time and it refuses to cancel. Since it does start, would you consider this a problem with the front control panel or a communication problem with the rear PCB? Unsure which to change first.
Thanks.
Get Special Offers Book washing machine & appliance repairs Buy appliance spare parts | Buy Appliances | Main help site is White goods help
#2 Washerhelp (Andy)
Washerhelp (Andy)
    Administrator
  • PipPipPip
  • 1,718 posts
  • Gender:Male
Posted 15 July 2012 - 02:58 PM
If you don't try to cancel the programme does it work OK and complete the wash cycle properly?
  • Disclaimer: You must be competent to carry out repairs, and accept responsibility for your own and other people's safety*
  • Please read - DIY repair safety and tips
* I use all reasonable efforts to ensure the information contained on Washerhelp is correct and accurate, no representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of such information. I therefore cannot be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information appearing on this website, which is given free of charge and in good faith.
Find a repairman | Buy appliance spare parts
I'm also a musician - Check out my Music
#3 d14ner
d14ner
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 16 July 2012 - 08:10 AM
Yes, the cycle completes. But it's a concern if I put something in and forget to lower the temperature and wish to reset.
#4 Washerhelp (Andy)
Washerhelp (Andy)
    Administrator
  • PipPipPip
  • 1,718 posts
  • Gender:Male
Posted 16 July 2012 - 10:03 AM
I presume you've used the cancel before ok and are doing it right? I know the cancel on my washing machine is tricky to use, designed like that to prevent accidental cancelling by ourselves or kids pressing buttons. If I press cancel on my machine lights flash but then I have to do something else within several seconds or the wash resumes.
If you have always used it without problem but now it won't work it's a very strange fault, I wouldn't think it worth all the expense to fix if it's only the cancel that's playing up.
#5 d14ner
d14ner
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 17 July 2012 - 04:59 PM
Yes, always been able to use without any problem previously. Used PCBs are not that expensive and we've several times managed repairs to thermostats/thermistors, have replaced the rubber seal and have replaced some buttons on the control panel. Bit of a triggers broom, but all else is well at the moment and wouldn't want to get a new machine when I could just switch out one of the boards.
#6 Washerhelp (Andy)
Washerhelp (Andy)
    Administrator
  • PipPipPip
  • 1,718 posts
  • Gender:Male
Posted 18 July 2012 - 10:21 AM
Could it just be the actual cancel button that's dodgy? Never heard of a faulty pcb that works perfect apart from won't cancel.
#7 d14ner
d14ner
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 18 July 2012 - 09:16 PM
The cancel button is the start button, so if the start button works?? ...
#8 Washerhelp (Andy)
Washerhelp (Andy)
    Administrator
  • PipPipPip
  • 1,718 posts
  • Gender:Male
Posted 19 July 2012 - 10:28 AM
In that case maybe not.
#9 d14ner
d14ner
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 19 July 2012 - 11:20 AM
Sorry, maybe not what? Which of the two boards do you reckon may be faulty? Whilst we don't mind doing repairs, don't want to switch one board only to find its the other.
#10 Washerhelp (Andy)
Washerhelp (Andy)
    Administrator
  • PipPipPip
  • 1,718 posts
  • Gender:Male
Posted 19 July 2012 - 07:03 PM
It was just a continuation of our previous conversation -
"Could it just be the actual cancel button that's dodgy? Never heard of a faulty pcb that works perfect apart from won't cancel
In that case maybe not."
The main pcb presumably monitors the start/cancel button to see if it is ever held in longer than the required period to instigate a cancel. Presumably it is recognising the cancel instruction because it flashes all the lights but I don't know why it would not then cancel the programme if everything on the machine is working OK. I would have to guess like you that it's a fault on the pcb but it's quite strange. I can't guarantee it would cure it and they are usually pretty expensive with no guarantee unless fitted by an engineer.
I would try to get it checked at somewhere like QER
#11 d14ner
d14ner
    Newbie
  • Members
  • Pip
  • 6 posts
Posted 21 July 2012 - 06:49 PM
Thanks. I'll probably leave it be for the time being since it actually starts and works when I ask it to.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
